Remove the row selector of FlexGrid
Posted by: sumit-man-cw on 14 September 2017, 11:54 am EST
    Posted 14 September 2017, 11:54 am EST
    Is there any way i can hide the row selector column (clicking on which i can select a row) i.e. the first column of a FlexGrid.
    For themes like “Clean Light” that column appears to be blank and still taking up space. Hence i would like to hide that column.
  • Posted 14 September 2017, 11:54 am EST
    Hi Sumit,
    For your information, first column in FlexGrid is referred as a row header. You can hide a row header by setting headersVisibility property to Column.
    For reference, please see the attached sample that implements the same.
    Manish Kumar Gupta
    2017/02/FlexGrid_rowHeader_hide.zip
    Thanks alot for the solution Manish.
  • Posted 30 November 2019, 5:11 pm EST
    How do you do it in Angular version?
  • Posted 2 December 2019, 12:18 am EST
    Hi Mark,
    You can set the headersVisibility property in the FlexGrid markup as follows:
    <wj-flex-grid [headersVisibility]="'Column'" [itemsSource]="source">
    </wj-flex-grid>
    https://stackblitz.com/edit/angular-7rnxih
