Render disabled cell in editabled row
Posted by: moritz.neugebauer on 28 September 2020, 8:45 am EST
  • Posted 28 September 2020, 8:45 am EST - Updated 3 October 2022, 3:30 pm EST
    Dear Wijmo Team,
    I’m currently trying to disable cells by using itemFormat EventHandler.
    When a column is readOnly, I want the cells to appear disabled.
    When a certain row is editable, I want the cells to appear editable
    But additionally, I want two certain columns to appear disabled, regardless of the certain row. How can I achieve this.
    Here is my code:
    //regular cells
                if (e.panel == s.cells) {
                    let item = s.rows[e.row].dataItem;
                    if (!item) {
                        return
    		// Disable isReadOnly row
                    let disabledCell: string = "disabled-cell";
                    if(item.isReadOnly) {
                        s.rows[e.row].cssClass = disabledCell;
    		// Enalbe special row
                    if(item.isSpecialRow) {
                        let classes = e.cell.classList;
                        classes.remove(disabledCell);
                    // Disable isReadOnly columns
                    let column = s.columns[e.col];
                    if(column.isReadOnly) {
                        column.cssClass = disabledCell;
    The result of this code looks like this
    • All columns are set to be readOnly
    • Only second row is editable
    But I want the first two columns of the second row to look disabled, too. How can I achieve that?
    Moritz
  • Posted 29 September 2020, 7:22 am EST
    Hello Moritz,
    For this, we need to set the cssClass for the First two columns. Please refer to the following demo link:
    https://stackblitz.com/edit/angular-euxwhd?file=package.json
    Manish Gupta
  • Posted 1 October 2020, 6:51 am EST
    Dear Manish,
    thank you for your response. In my case this works for the first two columns, because they have a special binding:
                    if(item.isEditable) {
                        if(s.columns[e.col].binding !== "serial" && s.columns[e.col].binding !== "somethingSpecial") {
    But I have other columns where I can’t decide that based on the columns binding. The data to decide that is stored in an array from which the columns are created…
    I need something like column.specialReasonWhyThisIsBlocked or something.
    Is is possible to add custom fields to a column in the create method of a column?
  • Posted 5 October 2020, 10:56 pm EST
    We can not have our own property for the columns with standard WjFlexGridColumn. But you may set the name property to access later the information.
    Also, you may derive your own class from the Column class and add the custom property.
    Please let us know if you would like further help and also share your environment detail (JS Framework/Language - JS/TS) so that we may assist you accordingly.
    Manish Gupta
