Replace "wj-groupmarker" template for items within "wj-group-panel"
Posted by: ewurzer on 21 December 2023, 2:00 pm EST
  • Posted 21 December 2023, 2:00 pm EST
    In a vue project I’m using a group panel:
    <wj-group-panel :initialized='onGroupPanelReady' :grid='grid' id='group-panel' placeholder='Drag columns here to create groups'></wj-group-panel>
    When columns are dragged up to it, they create groups as expected. I would like to change the HTML template for these items, however (the “wj-groupmarker” items).
    How can I do this? Currently I’m using raw DOM manipulation but its less than ideal.
  • Posted 26 December 2023, 12:27 am EST
    Sorry for the late reply. There is no direct method of modifying the default template of the group panel items. So, to modify the HTML template of the items formed in the GroupPanel, you need to overwrite the refresh method of the GroupPanel class. It is required because the items are created in this method. So, you may modify it accordingly as per your requirement.
    Please refer to this sample for reference: https://stackblitz.com/edit/vue-example-1-qtv6vq
    Also, if you just want to style the items, then it could be done using the CSS. You need to use the wj-groupmarker class for this.
    Please refer to this sample for reference: https://stackblitz.com/edit/vue-example-1-hg1b7b
    Thank you for your understanding and patience.
