Restore Layout dont apply CellTemplate VUE - ColumnLayout
Posted by: raphael.silva on 6 November 2020, 11:46 am EST
  • Posted 6 November 2020, 11:46 am EST
    I opened a topic
    https://www.grapecity.com/forums/wijmo/restore-layout-dont-apply-
    but now i have new problem.
    When i click load the grid this work and maintain the celltamplate OK.
    but the layout columns loaded run only first click, after don´t work and dont respect the .
    I’m send file code complet whit marks ///WIJMO FORUMLayoutGrid.zip
  • Posted 9 November 2020, 7:55 am EST
    Hi Raphael,
    Sorry, but I was unable to understand your issue properly. Can you please explain a little bit more about the issue?
    As per my understanding, you are using the column picker to change the visibility of the columns and the visible columns are not updated after loading the columns. Is my understanding correct?
    https://codesandbox.io/s/stupefied-euclid-m6fhl
    You can also modify the above to sample to replicate your issue.
