Rider / IntelliJ Intellisense - angular HTML
Posted by: kg on 9 September 2022, 4:42 am EST
    Posted 9 September 2022, 4:42 am EST
    Hello, I’m trying to get the HTML intellisence to work in my project, but for some reason I cannot make it work.
    It keeps saying “Unknown html tag” no matter what I do, I have even tried to look at a sample to see what I’m doing wrong but no matter what I do then the intellisence for HTML will not work for me.
    I’m working on an Angular 14 project, and currently I have installed the following npm packages Wijmo:
    "@grapecity/wijmo": "^5.20221.857",
        "@grapecity/wijmo.all": "^5.20221.857",
        "@grapecity/wijmo.angular.all": "^5.20221.857",
        "@grapecity/wijmo.angular2.all": "^5.20221.857",
        "@grapecity/wijmo.angular2.grid": "^5.20221.857",
        "@grapecity/wijmo.grid": "^5.20221.857",
        "@grapecity/wijmo.grid.sheet": "^5.20221.857",
        "@grapecity/wijmo.input": "^5.20221.857",
        "@grapecity/wijmo.styles": "^5.20221.857"
    I have also tried to include all the dist files from the downloaded zip file I have. But it still won’t work in my project.
    I would really like some help with this.
  • Posted 13 September 2022, 8:36 am EST - Updated 3 October 2022, 11:42 am EST
    I tried to replicate your issue, by installing the same versions of the components in an Angular 14 project, but the HTML intellisense is working fine in my case.
    I have the following extensions installed on VSCode:
    VSCode Version
    Version: 1.71.0 (user setup)
    Commit: 784b0177c56c607789f9638da7b6bf3230d47a8c
    Date: 2022-09-01T07:36:10.600Z
    Electron: 19.0.12
    Chromium: 102.0.5005.167
    Node.js: 16.14.2
    V8: 10.2.154.15-electron.0
    OS: Windows_NT x64 10.0.19043
    Sandboxed: No
    Here, is a sample for the same: demoProject.zip
    If you still face any issues then please share a sample replicating the issue, so that we can investigate the root cause and assist you accordingly.
  • Posted 15 September 2022, 7:47 am EST
    Hello, since that is for VSCode then I cannot use it for much.
    But I have found out that only the wj-flex-sheet is not working as it should. The wj-flex-grid does work and give me all the information in the intellise.
    And since I found out that the flexsheet was not what that should be used but rather the flexgrid then everything have sorted itself out.
  • Posted 16 September 2022, 12:13 am EST
    We are glad that you were able to resolve the issue on your own. Please let us know if you still face any issues.
    Sonu Kumar Pandey
