Posted 5 December 2019, 3:04 am EST
Hi Mark,
You will need to use the @Input decorator of the Angular component to provide data to the child component. To do this, first you will need to create a variable in the child’s component file:
export class HelloComponent {
@Input() source: any;
Then, provide the data from the parent component by accessing the source variable:
<hello [source]="data"></hello>
You may refer to the sample below:
https://stackblitz.com/edit/angular-uhawqp
In this sample, I have passed the data source of the FlexGrid from the parent component (app.component) to the child component (hello.component) and then to the FlexGrid.
You can read more about the @Input decorator from the link below:
https://angular.io/api/core/Input
