Posted 16 August 2022, 1:45 am EST
I want server side pagination and sorting on wijmo grid, I have check ODataCollectionView example our api won’t support that how can I achieve that with calls?
Bhagwati Pa
Posted by: bhagwati.pal on 16 August 2022, 1:45 am EST
Bhagwati Pa
Posted 22 August 2022, 12:36 am EST
We apologize for the delayed response you can extend the RestCollectionView class to create a custom RestCollectionView Class for example you can extend the RestCollectionView class to create a custom RestCollectionViewOData class that talks to OData sources. Or a custom RestCollectionViewReqRes class that talks to a ReqRes source. You can refer to the wijmo demo link below for reference:
Demo link:
https://www.grapecity.com/wijmo/demos/Core/CollectionView/RestCollectionView/OData/purejs
API link:
https://www.grapecity.com/wijmo/api/classes/wijmo_rest.restcollectionview.html
Posted 26 September 2022, 1:29 am EST
Hi Sonu,
Can you Please provide a sample to override this class, I want when I click in next or previous page I should be able to capture the event so I can pass values accordingly also same for filter
Bhagwati Pal
Posted 27 September 2022, 3:09 am EST
Paging :
You can refer to line 130 in the ‘rest-collection-view-odata.js’ file below sample, for customizing paging
You can also add an event handler on the navigator/pager element, if you want to perform any custom task while changing pages, refer to line 49 in the ‘app.js’ file.
Filtering :
For filtering, you can just add a filter to the grid, filtering is done on the server side by default, if you want to change that, you can change it through the ‘filterOnServer’ property. Also, if you have any custom condition for filtering data, you add it to the ‘setting.$filter’ string in the ‘RestCollectionViewOData’ class, You can refer to line 139 in the ‘rest-collection-view-odata.js’ file in the below sample, for its implementation.
Sorting :
You can use ‘sortOnServer’ property to enable/disable sorting on the server side, If you have any more customizations, you can refer to line 118 in the ‘rest-collection-view-odata.js’ file in the below sample.
Please find attached a sample for the same:
https://jscodemine.grapecity.com/share/BqUVvgGTT06affAC0XExrQ/
In case you still face any issues then please let us know.
Posted 28 September 2022, 5:06 am EST
I am passing collection to wijmo in below way.
this.list = new RestCollectionViewOData(result.list, {
pageSize: 10,
I created class
export class RestCollectionViewOData extends RestCollectionView {
private collection;
constructor(collection, options) {
super();
this.collection = collection;
this._totalItemCount = 110;
this.pageSize = 5;
getItems() {
if (this.collection) {
return this.collection;
} else {
return ;
I want to change data on page change
Posted 30 September 2022, 8:20 am EST
If you want to perform any custom tasks, when a page is changed, then you can handle ‘pageChanging’ event which occurs before the page index changes. You can write your custom logic inside this event. Please find attached an updated sample for the same(refer to line 30 in the app.js file):
