Posted 3 October 2019, 12:53 am EST
I want set cell tag on wj-flex-grid.
Posted by: lygiabao15ck1 on 3 October 2019, 12:53 am EST
Posted 4 October 2019, 1:43 am EST
We are sorry but we were not able to understand your use case. Could you please explain more about the behavior you wish to achieve so that I can help you find a solution?
Posted 6 October 2019, 10:20 pm EST
In wj-flex-grid cell. I want set text cell show in layout and other value hide in this cell.
Posted 7 October 2019, 3:29 am EST
As per your query , it seems you would like to set the custom content for cell. If this is the case, please refer to the following documentation:
https://www.grapecity.com/wijmo/docs/GettingStarted/Angular-Components#angular-markup-syntax
Also, please refer to the following demo sample for reference:
https://demos.wijmo.com/5/angular2/celltemplateintro/celltemplateintro/
In case, you did not add template, the cell shows the value for bind property for column.
Please refer to the sample:
https://www.grapecity.com/wijmo/demos/Grid/Overview/purejs
Hope it helps!
Manish Gupta
