Setting data column width in a Transposed grid
Posted by: jt on 20 June 2023, 5:42 am EST
    Posted 20 June 2023, 5:42 am EST
    Is there a way to set the width of data columns in a transposed grid?
    How would you set the width of the columns “Constant growth”, “Optimus prime” etc, in this example?: https://www.grapecity.com/wijmo/demos/Grid/TransposedGrid/RowGroups/angular
  • Posted 21 June 2023, 5:41 am EST
    To set the column width in TransposedGrid, you can handle the ‘loadedRows’ event of the grid and set it manually like this -
    loadedRows(s: any, e: any) {
            // set default size for all columns
            s.columns.defaultSize = 200;
            // set width of specific column in grid
            s.columns[0].width = 350;
    You can refer to the following sample for the same - https://jscodemine.grapecity.com/share/cH-LC0QV3E6zmObOrhVHuA
    Vivek Pannu
  • Posted 21 June 2023, 6:24 am EST - Updated 21 June 2023, 8:31 am EST
    Thanks! It works apart from one little thing:
    Apparently the first column and the first data column (marked with red arrows) is both at index 0. So when I set s.column[0].width both of them change. But I only want to set the width of the data column.
    How can I tell them appart?
    UPDATE UPDATE UPDATE:
    I figured it out :smiley:
    First set the default width of all the columns. This will also change the first column, but it can be overwritten by setting width for rowHeader column
    [code]loadedRows(grid:wjcGrid.FlexGrid,e:Event) {
    	grid.columns.defaultSize = 60;
    	grid.rowHeaders.columns[0].width = 90;
    }[/code]
    Maybe there is a cleaner solution, but this works.
  • Posted 22 June 2023, 12:47 am EST
    We are glad that you solved the issue on your own. Your approach to setting the rowHeaders column width through the rowHeaders panel of the flexGrid is correct and it will work as expected.
    In case, you have any further questions, please let us know.
