Posted 25 June 2021, 3:17 am EST
Yes, it is possible. You can set the different LineSymbols to each series of the chart(in your case method). You need to compare methods to the series name instead of htinfo.item.method, then the signs will be assigned to each series(method) instead of series points.
To change the legends signs, you may use the rendering event of FlexChart and place the new signs after removing old ones. Please refer to the code snippet:
renderingChart(chart) {
let legends = document.querySelectorAll('.wj-legend g');
legends.forEach((ele, index) => {
if (ele.children.length > 0) {
if (ele.children[0].tagName == 'ellipse') {
let fill = ele.children[0].attributes[2].value;
ele.children[0].remove();
ele.children[0].innerHTML = `<tspan fill=${fill}>${
this.signsArray[index]
}</tspan> method${index}`;
You may refer to the sample demonstrating the same:
https://stackblitz.com/edit/angular-bsfz5y
Note: To access the global variables inside the formatter method, you need to bind the formatter function to this and assign it to the new variable which you need to assign on the template side. Please refer to the above sample.
