Show 'ALL' checkbox in dropdown if dropdown is empty
Posted by: technical.store.technical on 22 June 2021, 7:36 am EST
    Posted 22 June 2021, 7:36 am EST - Updated 3 October 2022, 1:24 pm EST
    Hi Team,
    How can I show only ‘ALL’ checkbox in dropdown if the dropdown is empty.
    Example -
    For 2nd row - Subjects = “French” and SubSubjects = “11, 12”.
    Subsubjects dropdown is getting filtered based on the value present in the subjects column cell in the same row.
    So, Subject = “French” is not present in the dropdown of subjects column so my dropdown for subSubjects is empty (because subject = “French” has no associated subsubjects collection) and it is disabled in the sample.
    Now, my requirement is - when subsubjects dropdown is empty then the dropdown should be active and should show ‘ALL’ checkbox in it.
    https://stackblitz.com/edit/angular-jzx84h?file=src/app/app.component.ts
    Image of how dropdown should look like -
    Can you please provide solution for the above issue.
  • Posted 22 June 2021, 7:46 am EST
  • Posted 23 June 2021, 4:52 am EST
    Hi team,
  • Posted 23 June 2021, 11:21 pm EST
    We are working on this and will update you as soon as possible.
  • Posted 25 June 2021, 5:58 am EST
    Hi Ashwin,
    Is there any update ?
  • Posted 25 June 2021, 8:14 am EST
    To achieve the mention functionality, you need to check the subSubject column which has no items in the collectionView, and push the ALL inside the items. And to check the ALL at the time of initialization you need to push the new item into the checkedItems array of multiSelect. Please refer to the sample link below for reference:
    https://stackblitz.com/edit/angular-d6garh
    Also to you need to remove the wj-state-disabled class from the multiSelect to show drop down. Please refer to the sample.
  • Posted 28 June 2021, 2:28 am EST
    Hi Ashwin,
    1. This is not our requirement, we want single ‘ALL’ value in dropdown .
      In your snippet we can see ‘All’ and ‘ALL’ in dropdown. We want single ‘All’ in our dropdown.
    2. Also, This code works if you have direct data. This doesn’t work when we load data from the server because we don’t know the delay time. Is there any function or method in which we can run the enabling dropdown icon code.
    setTimeout(() => {
          let ele = document.querySelectorAll('.wj-input-group-btn');
          ele.forEach(btn => {
            if (wjcCore.hasClass(btn, 'wj-state-disabled')) {
              btn.classList.remove('wj-state-disabled');
              btn.children[0].removeAttribute('disabled');
        }, 100);
    https://stackblitz.com/edit/angular-be7sbh?file=src/app/app.component.ts
    In above snippet, We are not getting dropdown icon enabled because of the code execution sequence and we don’t want to increase the delay.
    Is there any other event which will work after initialized event.
  • Posted 28 June 2021, 2:37 am EST - Updated 3 October 2022, 1:24 pm EST
    We only want the highlighted part in dropdown if we don’t have data.
    Image : -
  • Posted 29 June 2021, 12:26 am EST
    Hi team,
  • Posted 29 June 2021, 11:35 pm EST
    1. The all checkBox is displayed when all the items inside the multiSelect are checked. So if we add only the all to the multiSelect the dropDown will not open as there will be no data to display. However, you can show the ALL in the dropDown which will be displayed on the multiSelect input. You also need to set the showSelectAllCheckbox property to false in order to show only one ALL checkbox in the dropdown.
    2. To resolve the issue regarding the delay, you may use the updatedView event of FlexGrid, which gets fired after the grid finishes creating/updating the elements that make up the current view.
    Please refer to the sample demonstrating both points:
    https://stackblitz.com/edit/angular-dks7bt
  • Posted 2 July 2021, 9:22 am EST
    Hi Ashwin,
    There is one issue with the above solution.
    When i click on 2nd row subsubjects column cell - it is getting cleared and ALL value is getting displayed in the dropdown.
    But after doing this if I add a new row or do pagination then the previous data appears on that cell.
    https://stackblitz.com/edit/angular-gvpp2r?file=src/app/app.component.ts
    Please Provide solution.
  • Posted 5 July 2021, 6:08 am EST
    I have updated the sample to not hide the ‘ALL’ value from the input element when the drop-down is displayed. Refer to line 105 where I have pushed the ALL value to the checkedItems:
    https://stackblitz.com/edit/angular-fycn3i
