Sort column position based on json data
Posted by: sneha.nagaruru on 11 February 2021, 8:13 am EST
    Posted 11 February 2021, 8:13 am EST
    Hi Team,
    I’m working with angular and typescript. Below is the requirement
    I have columnproperties json data as below
    {binding: ‘name’,header: ‘Name’,filterType: 3,visible: true, index:3},
    {binding: ‘userId’,header: ‘User ID’, filterType: 3,visible: true, index:1},
    {binding: ‘jobTitleName’, header: ‘Job’, filterType: 3,visible: true, index:2}
    I need to show column order based on the index. Is there any way to make it happen in wijmogrid.
    Also if the user sorts the columns by dragging the columns, I need the binding, header, index position information to save the user preferences.
    Please address both the requirements.
    Thanks & regards,
    Sneha Nagaruru
  • Posted 15 February 2021, 6:06 am EST
    Hi Sneha,
    You may simply sort the array based on index property and then use ngFor to create wj-flex-grid-columns. To save columns order after drag, you may handle the draggedColumn event and save the current order. Please refer to the following code sample which demonstrates the same:
    https://codesandbox.io/s/wijmo-angular-forked-x1cm9?file=/src/app/app.component.ts
    Sharad
  • Posted 15 February 2021, 6:41 am EST
    Hi Sharad,
    This demo works perfectly fine as per the requirement. Thanks for your help.
    The requirement got little bit changed. Even width is added to the colsInfo like
    {binding: ‘name’,header: ‘Name’,filterType: 3,visible: true, index:3, width:100}
    I have added width changes to the demo it working.
    I need help on getting the width of the columns when the user resizes them. Is their any handle to capture it.
    Thanks & Regards,
    Sneha Nagaruru
  • Posted 16 February 2021, 2:01 pm EST
    Hi Sneha,
    You may use the resizedColumn event to get notified about when the column width changes by dragging column.
    https://www.grapecity.com/wijmo/api/classes/wijmo_grid.flexgrid.html#resizedcolumn
    Sharad
