Sorting and Grouping with custom ColumnHeader
Posted by: mfrey43 on 13 December 2017, 6:16 am EST
  • Posted 13 December 2017, 6:16 am EST
    <wj-group-panel class="enable-flex objlist-header-start" [grid]="flexGrid" [maxGroups]="4" [hideGroupedColumns]="false"></wj-group-panel>
    <wj-flex-grid #flexGrid [itemsSource]="data" [isReadOnly]="true" [headersVisibility]="'Column'"
                  [deferResizing]="true" [preserveOutlineState]="false" [autoSizeMode]="'Both'" [selectionMode]="'Row'">
      <wj-flex-grid-filter></wj-flex-grid-filter>
      <wj-flex-grid-column [header]="'Text'" [binding]="'text'"></wj-flex-grid-column>
      <wj-flex-grid-column [header]="'Value'" [binding]="'value'">
        <ng-template wjFlexGridCellTemplate [cellType]="'ColumnHeader'" let-cell="cell">
          {{cell.col.header}}
        </ng-template>
    </wj-flex-grid>
    If you define a custom template for a column header it will no longer display the sorting glyph and the grouping label also won’t align correctly.
    What am I missing? My ultimate goal is to have a header that won’t display text (only filter and sorting) unless it’s shown in the group panel.
  • Posted 14 December 2017, 7:51 am EST
    Thank you for reporting this issue. We are able to replicate the issue at our end and it seems a bug. Hence, this issue has been escalated to the concerned team for further investigation with tracking id 301017.
    We will let you know as we get any update on this.
    ~Manish
  • Posted 19 July 2019, 1:16 pm EST
    Any updates on this? I am facing the same issue.
  • Posted 22 July 2019, 5:30 am EST
    Hi Igor,
    The issue is still with the dev team. We have told them to prioritize the issue. We will give you an updated as soon as the issue is fixed.
