Sorting not getting cleared in Wijmo Grid
Posted by: technical.store.technical on 11 June 2021, 2:11 am EST
    Posted 11 June 2021, 2:11 am EST
    I’ve implemented sorting in my grid but after sorting there is no way to clear it.
    How can i clear the sorting.
    example -
    Initial Sequence - [c, a ,b]
    After ascending - [a, b, c]
    After descending - [c, b, a]
    After clicking on the clear button of the sorting/filtering popup it doesn’t take me to the initial sequence.
    Snippet -
    https://stackblitz.com/edit/angular-bx2fkm?file=src/app/app.component.ts
    Please help me with this issue.
    Thank You.
  • Posted 13 June 2021, 11:59 pm EST
    Hi ,
    Can you please help us with the solution.
  • Posted 14 June 2021, 8:38 am EST
    Hi Srishti,
    The clear button in FlexGridFilter only clears the filter applied on the Grid. You may clear a sort applied on a column by ctrl+click on the column header.
    if you would like to clear sort programmatically, then you may call clear() method on gridInstance.collectionView.sortDescriptions as follows:
     <button (click)="flex.collectionView.sortDescriptions.clear()">Clear Sort</button>
    For better understanding, you may refer to the below code sample -
    https://stackblitz.com/edit/angular-8dl1rv
  • Posted 16 June 2021, 12:02 am EST
    Hi Ashwin,
    Thank you for the solution.
    It works.
