Specifying the data that a column filter applies to on a flex grid
Posted by: davidmartin-bennett on 23 October 2023, 7:44 am EST
    Posted 23 October 2023, 7:44 am EST
    Hi
    Is there a way to specify which data parameter a applies to, similar to the way we can set the sortMemberPath to tell the grid which data value the column sorts.
    So if we have a data object like
    data [
    DateOfBirth: 21/10/2023,
    OtherValue: “Something”
    DateOfBirth: 22/10/2023,
    OtherValue: “Something else”
    DateOfBirth: 23/10/2023,
    OtherValue: “Something other”
    the column could be set up as
    binding: ‘Age’
    sortMemberPath: ‘DateOfBirth’
    filterMemberPath: ‘DateOfBirth’
    This would then display the age in the grid but allow the user to sort and filter on the DateOfBirth parameter.
  • Posted 25 October 2023, 5:03 am EST
    Based on our understanding, you want to display ‘DateOfBirth’ values in the FlexGridFilter instead of ‘Age.’ If that’s the case, you can create a DataMap to associate DateOfBirth values with their corresponding Age values, and then set this DataMap in the ValueFilter’s dataMap property. For reference, please check out the sample link below:
    https://stackblitz.com/edit/angular-fmxjai?file=src%2Fapp%2Fapp.component.ts
  • Posted 25 October 2023, 5:10 am EST
    Hi
    That’s almost perfect, but what we actually want is to be able to filter by the DateOfBirth values in the flex grid filter, as in have them function as dates rather than text.
    The provided example almost does this but when selecting filter by condition, the conditions are for strings rather than Is Before, Is After etc that you could get with a date filter
    Kind regards
    David
  • Posted 26 October 2023, 1:31 am EST
    As per your use case, it seems that you only want to display ‘Age’ values in the ‘DateOfBirth’ column as you intend to perform sorting and filtering based on the ‘DateOfBirth’ as well. In that case, you can bind the column to ‘DateOfBirth’ and utilize cell templates to display ‘Age’ values within the cells. Additionally, set the ‘dataType’ property to “Date” to enable filter operators for the Date type column.
    If your data source contains date values in string format, you can override the ‘conditionFilter’ and convert the date string values into date objects to facilitate proper condition filtering. Please refer to the updated sample link below for more details.
    https://stackblitz.com/edit/angular-ppl1a4?file=src%2Fapp%2Fapp.component.html,src%2Fapp%2Fapp.component.ts
  • Posted 26 October 2023, 5:09 am EST
    Hi
    Yes this is exactly what I want, thank you
    Kind regards
    David
