Spline Chart is not curved at top
Posted by: sskss1ss2 on 11 August 2022, 8:38 am EST
  • Posted 11 August 2022, 8:38 am EST - Updated 3 October 2022, 11:48 am EST
    I’ve a spline chart plotted on X and Y Axis. The spline chart is not curved at top.
    Attaching screenshot for reference.
  • Posted 12 August 2022, 3:24 am EST
    As per the shared image, it seems that the values of some of the data points are exceeding the max point of the Y-axis, therefore the curves seem to be cut off. To resolve the issue you mat to set the max property value of axisY to a higher number. You can refer to the sample link below for reference:
    https://stackblitz.com/edit/js-f97uju?file=index.js
    API link: https://www.grapecity.com/wijmo/api/classes/wijmo_chart.axis.html#max
    In case the issue still persists please share a small sample replicating the issue. So that we can investigate further and assist you accordingly.
