Posted 7 December 2019, 9:46 am EST
I ma implementing Flexgrid into a dashboard. Out of stock control doesn’t look too pretty in relation to a dashboard concept. Do you have any samples of grids being styled better for dashboards?
Posted by: mark.goldin on 7 December 2019, 9:46 am EST
Posted 9 December 2019, 2:57 am EST
Hi Mark,
You can try using the wijmo themes that are included in the package by default. Since you are using CDN links for adding the CSS, you can add another link tag to import the theme from the CDN link. For example, if you are using the ‘modern’ theme, you may the following CDN link:
https://cdn.grapecity.com/wijmo/5.20193.637/styles/themes/wijmo.theme.modern.min.css
The sample below provides a demo for each of the themes available in wijmo:
https://jsfiddle.net/Wijmo5/eg3yfe56/
You can also use the theme designer to design your own themes:
https://demos.wijmo.com/5/Angular/ThemeDesigner/ThemeDesigner/
Simply create a theme and copy the CSS from the CSS into your style files.
