Submit wijmo input
Posted by: tuananhuet.work on 3 January 2024, 10:57 pm EST
    Posted 3 January 2024, 10:57 pm EST
    hi all
    i have problem that, when i input number by ipad and submit, i get Warning: flushSync was called from inside a lifecycle method. React cannot flush when React is already rendering. Consider moving this call to a scheduler task or micro task. but in pc i dont have get it. anyone have solution for it ?
  • Posted 4 January 2024, 4:36 am EST
    As per our understanding, you are using Wijmo’s InputNumber control in your React project and facing this issue on your iPad, if so, then we are not able to replicate the issue on our end, could you please share a small sample in which the issue can be replicated so that we can further investigate the issue and assist you accordingly?
    Here’s the sample in which we tried to replicate the issue - https://stackblitz.com/edit/react-5d3def?file=Hello.js
    You can also modify the above sample to replicate your issue and share it with us.
    In case, if there is something we missed, please let us know.
