Posted 2 November 2019, 5:35 pm EST
I am working with a .net core 2.2 application and trying to load cell notes when initializing my grid. Here is my code;
addGrid = function (controlName, icons) {
var tooltip = new wijmo.Tooltip(), rng = null; var invoiceGrid = new wijmo.grid.FlexGrid(controlName, { columns: [ my code defining columns ], formatItem: function (s, e) { if (e.panel == s.cells) { var item = s.rows[e.row].dataItem, binding = s.columns[e.col].binding, note = item.notes ? item.notes[binding] : null; toggleClass(e.cell, 'wj-has-notes', note != null); if (note != null) { tooltip.setTooltip(e.cell, '<b>Comments:</b><br/>' + note); } } } }); return invoiceGrid
When I run application I get the error toggleClass is not defined. I am including the following scripts;
<script src="~/js/wijmo.chart.min.js"></script> <script src="~/js/wijmo.grid.min.js"></script> <script src="~/js/wijmo.nav.min.js"></script> <script src="~/js/wijmo.input.min.js"></script>
Also, do you have an example of how to add/edit a cell note while the application is running and after the grid has been loaded?
Thanks, Ed
