Tree Grid Want to reserve First Column for selection check box not for grouping
Posted by: pmithilesh on 5 February 2024, 3:33 pm EST
  • Posted 5 February 2024, 3:33 pm EST - Updated 5 February 2024, 3:38 pm EST
    we have Tree grid with parent child items. we have new requirment which needs first column to be reserved for few thing like check box
    but whenever i try to put the first column groping are getting moved to first column which should be on second columns
    Please find attached Image for the problem we wanted name column to have name Column as Tree node/group not the first column
    Thank you
  • Posted 6 February 2024, 1:39 am EST
    To achieve the desired requirement, you can use ng-template to create custom expand/collapse icons in any specific column and perform the detail row expand/collapse actions on those icons. To provide padding according to the hierarchy, you can add a handler on the formatItem event. This handler will also be used to remove the padding from the first indexed column. Please refer to the sample link below demonstrating the same:
    https://stackblitz.com/edit/angular-tyerut?file=src%2Fapp%2Fapp.component.ts,src%2Fapp%2Fapp.component.html
