Two multi select listbox am using when i check checkbox checked event not fired
Posted by: bemes9226 on 27 July 2021, 12:32 am EST
  • Posted 27 July 2021, 12:32 am EST
    in angular 2,
    when check checkbox it is checked but am unable to get fired any event like
    checkedItemsChanged,checkedItems…
    but when i click content of the text it is fired.but when select checkbox only checked not fired.
    <wj-multi-select-list-box
    #listBox
    [showSelectAllCheckbox]=“showSelectAllCheckbox”
    (checkedItemsChanged)=“setAddData(listBox, $event)”
    (checkedItems)=“setCheckedItems(listBox,$event)”
        class="multiSelect"
        [itemsSource]="columnsAvailable"
        (ngModelChange)="modelChanged($event)"
    ></wj-multi-select-list-box>
  • Posted 27 July 2021, 12:33 am EST - Updated 3 October 2022, 12:28 pm EST
  • Posted 27 July 2021, 12:35 am EST
    event not fired only check box checked but when click on text it fired event
    checkedItemd
  • Posted 27 July 2021, 7:42 am EST
    first time working fine but second time open popup and click on the checkbox only,not in text events not fired.when i clcik text it is fired
  • Posted 28 July 2021, 3:48 am EST
    Hi bemes9226,
    We are unable to replicate the issue at our end. And in the provided code snippet, We could observe that the checkedItems property is bind with a function while it should be bind with an array. That may be the cause of the issue.
    You may bind checkedItems property with an array. If the issue still persists. Kindly make changes to the below code sample to reproduce the issue -
    https://stackblitz.com/edit/angular-qappfn
  • Posted 15 September 2021, 3:30 pm EST - Updated 3 October 2022, 12:28 pm EST
    i am getting this error when checkbox checked in listbox.
    checkeditemchanges not hitting .
  • Posted 15 September 2021, 3:34 pm EST
    <wj-multi-select-list-box #listBox [showSelectAllCheckbox]=“true” style=“margin-top: 7px;”
    (checkedItemsChanged)=“setAddData(listBox)” class=“multiSelect”
    [itemsSource]=“columnsAvailable”
    setAddData(s) {
    this.checkeditem = ;
    this.checkeditem.push(s.checkedItems);
    if (this.checkeditem.length >= 1) {
    this.isSelected = false;
  • Posted 16 September 2021, 12:01 am EST
    Sorry but I was unable to replicate the issue. It could be possible that there is some issue in your data source. Can you modify the sample below so that it replicates your issue?
    https://stackblitz.com/edit/angular-ommoz1
  • Posted 16 September 2021, 8:55 am EST
    for popup am using ngbootstrap(ngbModule).
    <ng-template #tanantName let-c=“close” let-d=“dismiss”>
    <div class="modal-header tenantStyle">
      <h1 class="modal-title">Assign Tenant</h1>
      <button type="button" class="close" aria-label="Close" (click)="c('Close click')">
        <span aria-hidden="true">&times;</span>
      </button>
    </div>
    <div class="modal-body">
    <div class="row">
      <div class=" addStyles" style="background: #d5d6d8;width: 46%;margin-left: 2%;">
        <div class="addhead" style="padding: 7px;">
          <div style="width: 66%;float: left;margin-left: 9px;">
            <span class="bento-search">
              <input
                class="form-control"
                [(ngModel)]="AddSearch" (ngModelChange)="sharedVarChange($event)" (input)="columnsAvailable.refresh()"
                type="text"
                name="demoSearch"
                placeholder="Filter"
            </span>
          </div>
        <div style="float: right;">
          <span>
            <button [disabled]="isSelected" class="btn btn-primary btn-sm" (click)="addColumn();"
            style="float: left;margin-right: 12px;padding: 15px;">ADD<span style="margin-left: 4px;" class="bento-icon-chevron-medium-right"></span></button>
          </span>
        </div>
        </div>
        <div>                    -->
      <wj-multi-select-list-box #listBox [showSelectAllCheckbox]="true" style="margin-top: 7px;"
      (checkedItemsChanged)="setAddData(listBox,$event)" class="multiSelect"
      </div>
      <div class="removeStyles" style="background: #d5d6d8;width: 45%;">
          <span style="float: left;padding-left: 5px;">
            <button (click)="removeColumn();isRemoveSelected=true;" [disabled]="isRemoveSelected" class="btn btn-primary btn-sm" style="float: left;margin-right: 4px;padding: 15px;">
              <span style="margin-right: 4px;" class="bento-icon-chevron-medium-left" ></span>REMOVE</button>
          </span>
          <span class="bento-search" style="float: right;">
            <input
              [(ngModel)]="removeSearch" (ngModelChange)="sharedVarChange1($event)" (input)="TanantData.refresh()"
              type="text"
              name="demoSearch"
          </span>
        </div>
        #listBox1 style="margin-top: 7px;"
        (checkedItemsChanged)="setRemoveData(listBox1, $event)"
        [showSelectAllCheckbox]="showSelectAllCheckbox"
       class="multiSelect"
        [itemsSource]="TanantData"
      </div>
    </div>
    </div>
      <div class="modal-footer" style="text-align: center;">
        <button type="button" class="btn btn-primary" (click)="getResultData();c('Close click')">OK</button>
        <button type="button" class="btn btn-outline-primary" (click)="c('Close click')">Cancel</button>
    </div>
    this.modalService.open(this.tanantName, {windowClass: ‘MainTemplate’,backdrop: ‘static’, keyboard: false});
  • Posted 20 September 2021, 8:37 am EST
    We apologize, but still, we are unable to replicate the issue at our end. Could you please provide a sample replicating the issue, You can either modify the sample below to replicate the issue:
    sample link:https://stackblitz.com/edit/ng-bootstrap-modals-7ntw4f?file=src%2Fapp%2Fmodal-content%2Fmodal-content.component.html
    In the above sample, I have used the code snippet provided by you in your response above, feel free to update the sample to replicate the issue and send us back so that we can provide you better assistance.
