Posted 27 July 2023, 3:26 am EST
We are using both the things n our code and need to write the unit test case for the same. Please provide sample documents so that it can help us to write cases.
Using wjcCore.CollectionView for storing data
Posted by: AAl-ismail on 27 July 2023, 3:26 am EST
Posted 28 July 2023, 6:30 am EST
There is no official documentation yet available for writing unit tests on Wijmo controls, however, you can refer to the attached sample in which some basic testing is performed on FlexGrid and FlexGridFilter. Similarly, you can write more unit tests as per your requirements.
Posted 2 August 2023, 3:51 am EST
Facing the below error. How to solve it
Assertion failed in Wijmo: Invalid columnLayout data. Error:
at assert (http://localhost:XXXX/karma_webpack/webpack:/node_modules/@grapecity/wijmo/es5-esm.js:14:15787)
at WjFlexGrid.set [as columnLayout] (http://localhost:XXXX/karma_webpack/webpack:/node_modules/@grapecity/wijmo.grid/es5-esm.js:14:64878)
Posted 3 August 2023, 12:43 am EST
Sorry, but we are unable to replicate the issue on our end. Could you please update the attached sample to replicate the issue so that we can further investigate the issue and assist you accordingly?
