Use third-party library as custom editor?
Posted by: matt_baker on 6 April 2021, 10:31 pm EST
  • Posted 6 April 2021, 10:31 pm EST
    Is there an interface, or way to extend a Wijmo Input control to wrap a third-party library as an editor in FledGrid? I have a need for a multi select, tag-like editor for a column that contains an array of values, and none of the Wijmo Input’s set that specific need. I’ve been looking at Tagify (https://github.com/yairEO/tagify)
  • Posted 7 April 2021, 4:38 am EST
    Hi Matt,
    You can use MultiAutoComplete for these requirements. This control does not support tags by default but with a little tweak, we can add support for tags.
    You can refer to the sample attached.
    Ashwintags.zip
  • Posted 7 April 2021, 2:57 pm EST
    Ashwin,
    Thanks for the reply! The tag code does work, but it appears that it interferes with the edit events if “trackChanges: true” is set.
    See attached project. If I edit tags and switch rows, the edited row is not added to itemsEdited. If I copy that row and paste into another, the pasted row appears in itemsEdited.
    Also, It appears that cancelling edits isn’t working, but I did not build a test for it.
    Archive.zip
  • Posted 9 April 2021, 12:12 am EST
    Hi Matt,
    I was able to replicate both issues. I will investigate this and will update you as soon as possible.
  • Posted 12 April 2021, 12:38 am EST
    Hi Matt,
    I am extremely sorry for the delayed response. This seems like a bug in control. I have asked the dev team to look into this. The internal tracking id of the case is WJM-19680.
    I will update you once I will hear from them.
  • Posted 14 April 2021, 4:47 pm EST
    Thank you for your response. Please let me know when an update is available.
