Posted 1 May 2020, 5:45 am EST
seriesStyle: any = {
fill: ‘var(–link-color-light)’,
stroke: ‘var(–link-color-light)’
getting error in flexchart .
‘Cannot read property ‘0’ of null’
Posted by: spathi on 1 May 2020, 5:45 am EST
Posted 4 May 2020, 1:26 am EST
We were able to replicate the issue at our end so we have forwarded this to the dev team with internal tracking id 433599. We will update you once this issue is fixed.
In the meantime, as a workaround, instead of setting the fill and stroke property in the JS, you may assign a cssClass to the series and customize the series in CSS directly. Please refer to the sample link below for reference:
https://stackblitz.com/edit/js-sjzeku
Posted 4 May 2020, 3:00 am EST
Thanks Aswin, here i’m changing the fill and stroke values based on condition
Posted 5 May 2020, 12:19 am EST
As you were changing the style of the series based on the condition, similarly you can add different CSS classes and change the cssClass property based on the same condition.
Posted 28 July 2020, 4:16 am EST
Hi Spathi,
The issue has been fixed in the latest nightly build of Wijmo. You may verify the same using the sample link below:
https://stackblitz.com/edit/js-xzrohm
This fix will be included in the next stable release.
PS: Nightly builds have not passed through the QA cycles as all of our release builds do. So, it is not recommended to use nightly builds in production.
