Using wj-flex-grid-filter with wj-flex-grid
Posted by: pradnya.choudhari on 29 October 2019, 9:48 am EST
  • Posted 29 October 2019, 9:48 am EST
    I am using wijmo version 5.20171.282 and angular version 4.1
    I am trying to implement a basic filter for wj-flex-grid.
    I ahve gone through several of forum questions and other example and found many.
    One specific one is given below:
    Taken from below topic
    https://www.grapecity.com/forums/wijmo/changing-default-filter-no
    init(grid:wjcGrid.FlexGrid,filter:wjcGridFilter.FlexGridFilter){
    filter.defaultFilterType=wjcGridFilter.FilterType.Condition;
    var colfil=filter.getColumnFilter(‘country’).conditionFilter;
    var Operator=wjcGridFilter.Operator;
    wjcCore.culture.FlexGridFilter.stringOperators=[
    { name: ‘Contains’, op: Operator.CT },
    { name: ‘Equals’, op: Operator.EQ },
    { name: ‘Begins with’, op: Operator.BW },
    { name: ‘Ends with’, op: Operator.EW },
    //similarly you can also set numberOperators,dateOperators, booleanOperators
    my issue is with my version of wijmo the wjcGridFilter does no loner support FilterType.
    All I see is it offers wjcGridFilterModule, wjcGridFilter, and wjcGridFilterMeta
    In that case how do I use above example to implement a simple filter.
    I need the filter to apply to single column.
    thanks,
    Prad
  • Posted 30 October 2019, 2:01 am EST
    Hi Pradnya,
    As per my understanding by looking at the snippet provided, I think that you have imported the wrong module in your component file. Please try updating the import statement:
    import * as wjcGridFilter from 'wijmo/wijmo.grid.filter';
    Let me know if this solves your issue or otherwise.
