Vertical scrollbar not showing up
Posted by: muddam.kranthi on 20 May 2022, 1:49 am EST
  • Posted 20 May 2022, 1:49 am EST
    Hi Team,
    The vertical scroll bar is not showing even if I gave the fixed height to the grid.
    <wj-flex-grid #flexGridBill class=“bento-flex-grid has-row-hover” [isReadOnly]=“true”
    [itemsSource]=“targetGridBill” [stickyHeaders]=“true” [showMarquee]=“true” [showSort]=“true”
    (initialized)=“gridInitialized(‘Bill’)” id=“grdTargetBill” style=“max-height: 280px;”>
    I gave height as 280px and I have data more than that height. I can scroll the remaining data with the help of down arrow and mouse but why the scrollbar is not showing up when height is given fixed. We need the scrollbar so that end user knows there is more data in the grid.
    could you please help here.
    Kranthi
  • Posted 23 May 2022, 7:15 am EST
    We apologize but we are unable to replicate the issue at our end, could you please refer to the below sample used to replicate the issue and let us know if any changes are required to replicate the issue at our end?
    If you are facing the issue only in your application and not in the below-shared sample, it might be possible that the issue is caused due to some other factors in your application therefore I would request you to please share a small sample replicating the issue.
    Sample link: https://stackblitz.com/edit/js-j68wcw?file=index.js
    Sonu Kumar Pandey
