verticalAlign of ICellStyle in applyCellsStyle Methods not working (Flexsheet)
Posted by: ngvanthuong97 on 12 July 2019, 12:30 am EST
    Posted 12 July 2019, 12:30 am EST
    I want to set Cell Style in WjFlexSheet. So, I used to applyCellsStyle Method.
    • “applyCellsStyle(cellStyle: ICellStyle, cells?: CellRange, isPreview?: boolean): void”
    All properties of the ICellStyle Interfaces work except verticalAlign.
    This is my code:
    this._sprTemp.applyCellsStyle({
                    textAlign: 'left',
                    verticalAlign: 'middle',
                    fontFamily: 'Arial',
                    fontSize: '12px'
                }, [new CellRange(0, 0, 50, 36)]);
    Help me, please!
  • Posted 15 July 2019, 5:20 am EST
    The reason that vertical-align is not working because it does not work on the block-level elements i.e. the elements whose display is set to block and each cell of the FlexSheet is a block-level element.
    To vertically align the elements, you may use the itemFormatter property of FlexSheet and add another span element inside each cell and make it vertically-align. Please refer to the sample below:
    https://stackblitz.com/edit/angular-vsz7dz
  • Posted 16 July 2019, 3:27 am EST
    Hi ashwin.saxena,
    I used the itemFormatter property but vertically-align still couldn’t work even if I don’t use merge
    formatSheetInit() {
                textAlign: 'left',
                fontSize: '12px'
            this._sprTemp.itemFormatter = function (panel, row, col, cell) {
                const oldHTML = cell.innerHTML;
                cell.innerHTML = `<span class="v-center">${oldHTML}</span>`;
  • Posted 17 July 2019, 5:49 am EST
    Hey,
    The issue may be arising due to CSS. Please ensure that you have added the ‘v-center’ class in the global CSS file from the sample that I provided earlier. If this does not solve the issue, could you please provide us a sample that replicates the issue so we can investigate further.
  • Posted 17 July 2019, 10:50 pm EST
    The problem is that when I show up on the screen, the ‘v-center’ class working, and text-align does not. But when I export it to EXCEL it is the opposite.
    I don’t know what happened when I executed the EXCEL export command
    this._sprTemp.saveAsync('example.xlsx');
  • Posted 19 July 2019, 7:07 am EST
    Regarding cells not vertically aligned in excel:
    We were able to replicate the issue at our end so we have forwarded a bug report to the dev team with internal tracking id 390801. We will give you an update as soon as the issue is fixed.
    Regarding text-align not working in browser:
    We are sorry but we were not able to replicate the issue. The text-align property is working as expected on both the browser and excel. Could you please provide us with the exact steps to replicate so we can investigate further.
