Vue and wj-auto-complete
Posted by: 20je0018 on 22 July 2023, 7:00 am EST
    Posted 22 July 2023, 7:00 am EST
    Hey everyone,
    Abhay here, I am working on a project as an intern using wijmo.vue2.all version 5.20192.624. I am working on a dashboard which has been developed using Laravel and Vue.
    I want to use pre-written
    wj-auto-complete
    element and store the selected item from the dropdown list (as an item is selected) in an object defined in same vue component.
    <wj-auto-complete
                            class="form-control"
                            search-member-path="customer_name"
                            display-member-path="customer_name"
                            selected-value-path="id"
                            :selected-index="-1"
                            :is-required="false"
                            :initialized="initCustomer"
                            :max-items="customerList.length"
                            :items-source="customerList"
                         ></wj-auto-complete>
    the implementation of the existing wj-auto-complete is as above. I have gone through the documentation but could not figure out the way to do it.
    Any help will be highly appreciated.
  • Posted 24 July 2023, 4:47 am EST
    Hi Abhay,
    You can handle the ‘selectedIndexChanged’ event of the AutoComplete to store the selected reference, as per your requirements. You can refer to the following sample demonstrating the same - https://jscodemine.grapecity.com/share/reH0qbKU3UuTFazHH4-uSQ
    You can refer to the following API link for more information about the methods, properties, and events that you can use for the AutoComplete control - https://www.grapecity.com/wijmo/api/classes/wijmo_input.autocomplete.html
  • Posted 24 July 2023, 6:22 am EST
    Thankyou Vivek,
    :slight_smile: Hope you are having a great day.
    Thanks for the solution. You’re a lifesaver!!
