Posted 5 May 2023, 1:40 am EST
We are using Wijmo 5.20222.877, which we understand to be compatible with Angular Ivy (as of Angular 9). We are declaring our dependencies against @grapecity/wijmo.angular2 packages.
After attempting to upgrade to Angular 16, we get compilation errors such as:
error NG6002: 'WjCoreModule' does not appear to be an NgModule class.
node_modules/@grapecity/wijmo.angular2.core/index.d.ts:195:22
195 export declare class WjCoreModule {
This likely means that the library (@grapecity/wijmo.angular2.core) which declares WjCoreModule is not compatible with Angular Ivy. Check if a newer version of the library is available, and update if so. Also consider checking with the library's authors to see if the library is expected to be compatible with Ivy.
Are you aware of this, and are there plans in the pipeline to add such support? This will block our upgrade until addressed.
