Wijmo Checkbox selection column not showing up
Posted by: sneha.nagaruru on 4 March 2021, 6:28 pm EST
  • Posted 4 March 2021, 6:28 pm EST - Updated 3 October 2022, 2:19 pm EST
    I have tried to implement https://www.grapecity.com/wijmo/demos/Grid/Selection/CheckboxSelection/angular but the checkbox column is not showing up.
    <label>
        Header Column
        <input #headersCheckbox type="checkbox" [checked]="headers" (change)="setHeaders(headersCheckbox.checked)" />
    </label>
    <wj-flex-grid #flexGrid class="bento-flex-grid" [class.list-grid]="isListGrid" [itemsSource]="data"
        [stickyHeaders]="true" [showMarquee]="true" [showSort]="true" (initialized)="initGrid(flexGrid)"
        [allowSorting]="'MultiColumn'" [alternatingRowStep]="0" [deferResizing]="true">
        <!-- FLEXGRID FILTER -->
        <wj-flex-grid-filter #filter></wj-flex-grid-filter>
        <!-- Actions Column -->
        <wj-flex-grid-column [header]="'Actions'" [binding]="'actions'" [minWidth]="150" [width]="150" [isReadOnly]="true"
            [allowSorting]="false" [allowDragging]="false" [cssClass]="'action-column'">
            <ng-template wjFlexGridCellTemplate [cellType]="'Cell'" let-col="col" let-row="row" let-item="item">
                <span class="bento-icon-edit grid-action-icon" (click)="actions.editRow(item)" ngbTooltip="Edit"
                    container="body" title="Edit"></span>
                <span class="bento-icon-folder grid-action-icon" (click)="actions.editRow(item)" ngbTooltip="Attach"
                    [style.display]="!toggleStatus ? 'inline' : 'none'" container="body" title="Attach"></span>
                <div ngbDropdown [container]="'body'" class="grid-dropdown">
                    <button aria-label="Select more action" class="btn btn-outline-primary btn-xs dropdown-toggle"
                        ngbDropdownToggle (click)="actions.showOptions(item)">
                        More
                        <i aria-hidden="true" class="bento-icon-caret-down-filled"></i>
                    </button>
                    <div ngbDropdownMenu aria-labelledby="dropdownBasic1">
                        <button ngbDropdownItem
                            [ngClass]="option.IsEnabled === true ? 'dropdown-item' : 'disable-dropdown-item'"
                            *ngFor="let option of moreOptions; let i = index;" (click)="onActionSelect(option,row.index)"
                            [hidden]="!option.Visibility">{{option.displayName}}</button>
                    </div>
                </div>
            </ng-template>
        </wj-flex-grid-column>
        <wj-flex-grid-column *ngFor="let col of gridColumns" [header]="col.header" [binding]="col.binding"
            [visible]="col.visible" [width]="col.width" [isReadOnly]="true">
            <ng-template *ngIf="col.binding=='severity_color'" wjFlexGridCellTemplate [cellType]="'Cell'" let-item="item">
                <img src="assets/images/{{item.severity_color.toLowerCase()}}.PNG" alt="{{item.severity_color}}"
                    width="15px" height="15px" />
            </ng-template>
            <ng-template *ngIf="col.binding=='wsu_checklist'" wjFlexGridCellTemplate [cellType]="'Cell'" let-item="item">
                <a href="#!" alt="{{item.wsu_checklist}}">{{item.wsu_checklist}}</a>
            </ng-template>
            <ng-template *ngIf="col.binding=='wsu_followup'" wjFlexGridCellTemplate [cellType]="'Cell'" let-item="item">
                <div *ngIf="item.wsu_followup == 'true'"><span class="bento-icon-flag-filled grid-action-icon"></span>
                </div>
            </ng-template>
    </wj-flex-grid>
    When the header column is unchecked the row height gets increasing
    Please let me know if I’m missing anything.
  • Posted 5 March 2021, 4:39 am EST
    Hi Sneha,
    Could you please check if there is any error on the console. I tried adding selector and it is working fine on my end. You may refer to the following sample:
    https://codesandbox.io/s/wijmo-angular-forked-dvutf?file=/src/app/app.component.ts
    Regarding the rowheight increase issue, the issue seems something specific to your application, could you please share a sample that demonstrates this issue for us to investigate or you may also update the above-shared sample to replicate the issue.
  • Posted 5 March 2021, 5:52 am EST
    Hi Sharad,
    I have updated the same in code and it is still not working. I will share with you the prototype of my project by the end of the day.
    Sneha
  • Posted 5 March 2021, 3:12 pm EST - Updated 3 October 2022, 2:20 pm EST
    Hi Sharad,
    I herewith provide the prototype of the project along with mockup’s for better understanding.
    case URL: https://www.grapecity.com/my-account/my-support/case/f2cfb6d0-e57d-eb11-a812-000d3a8bd0b7
    My requirement is on togglebutton click (Multi-select) I need to show and hide the checkbox column with grouped data in the wijmogrid.
    Also, an alert should be shown if on another button click like in the toolbar when a different group of data is selected.
    Sneha
  • Posted 5 March 2021, 3:15 pm EST
    P.S. please check package.json file if any wijmo package need to added.
  • Posted 8 March 2021, 4:13 am EST
    Hi Sneha,
    Thank you for the sample. We have responded on the support portal. Please refer to the same.
