Wijmo datepicker
Posted by: samvarth123 on 30 March 2020, 9:30 am EST
    Posted 30 March 2020, 9:30 am EST
    Hi team !
    Is there a provision in wijmo date pickers to do the below : Instead of using the data picker or typing a date, user should be able to type shortcuts Eg : 1) T-1 = Yesterdays Date 2)T-10 = Date 10 days ago 3)“T” for todays date 4) T+2 = Date two days in future
    If you have similar thing please provide an example or approach to do the saem
    We are using angular 7
  • Posted 31 March 2020, 6:42 am EST
    I have replied to your case here:
    https://www.grapecity.com/forums/wijmo/wijmo-datepicker-
    For reference, I am copying the solution below:
    This is not supported in InputDate but you can add its support manually. You will need to handle the event of which the Enter key is pressed and parse your expression.
    Please refer to the sample below for reference:
    https://stackblitz.com/edit/ckkyne-r3ovg1
