Wijmo Flex Grid - Custom Date filter
Posted by: ankita on 9 May 2019, 4:51 pm EST
  • Posted 9 May 2019, 4:51 pm EST - Updated 3 October 2022, 8:04 pm EST
    I am using wijmo pure js.
    Is their a way to show calendar in Wijmo flex grid column filter?
    We want to show the calendar where user can select multiple days or a date range and grid will show all records that falls under that range.
    Thanks you.
  • Posted 10 May 2019, 6:54 am EST
    Hi Ankita,
    If you would like to filter for a range using the calendar, you may use the condition filter.
    The FlexGridFilter UI is the same as Excel filtering. In excel, valueFilter shows the list of values to select filter items.
    Also using the Calendar for value filter do not seems OK since here the user may select dates for which there are no records in FlexGrid.
    Further, it would not be easy to retain the selection state for Calendar control while the user is selecting dates from multiple months or years.
    Hope it clears!
    Manish Gupta
