Wijmo flex sheet auto fill area display issue
Posted by: m.mironenko on 10 June 2021, 7:20 am EST
  • Posted 10 June 2021, 7:20 am EST - Updated 3 October 2022, 1:39 pm EST
    I have following UI issue around wijmo flex sheet auto fill functionality: when we drag mouse to the bottom then table scrolls because of it and as a result dotted area capture the header as well and displays over the header.
    Do I have a chance to fix it?
  • Posted 11 June 2021, 12:39 pm EST
    We are able to replicate the issue at our end and hence we have escalated it to the concerned team for further investigation of the issues. The internal tracking id for the issue is WJM-20195.
    Till the issue is fixed, you may use the following CSS to fix the issue at your end:
    .wj-header {
      z-index: 10000;
    You may also refer to the following sample: https://stackblitz.com/edit/js-jofwvk?file=index.js
