Posted 29 July 2020, 6:39 am EST
Hello, can You provide me with code that merges column headers and also just some certain columns in flexgrid, columns with certain id/name…
Thanx!
Posted by: mary431982 on 29 July 2020, 6:39 am EST
Thanx!
Posted 30 July 2020, 12:58 am EST
Please refer to the demo link below:
https://www.grapecity.com/wijmo/demos/Grid/Merging/CustomMerging/purejs
This sample demonstrates how you can use the MergeManager class to provide custom merging in FlexGrid. This sample only shows how to merge cells but the same concept can be used to merge headers of the grid.
Posted 6 August 2020, 4:38 am EST
Thanx for your reply,
I have seen this example and I’ve tried to change it for my needs, but I can’t manage to succeed to get what I want, I need only column header rows to be merged vertically AND horizontaly, and regular non header cells to be merged vertically only for some certain columns that are hard-coded.
Posted 6 August 2020, 5:42 am EST
For example, I have 2 column header rows, and for each column - cells in Column header rows are equal and I want them to be merged vertically!! (for each column);
but - for non column header rows - I want only one column (for example the second one) to have merged cells vertically!
I can’t get it to work…
Posted 6 August 2020, 6:03 am EST
Maybe I finally did it, instead of using r < columnHeader.rows.length for trying to merge column header row cells - I am now using: panel.cellType == 2…
Posted 7 August 2020, 12:43 am EST
Hi Mary,
Can you let me know if your issue is fixed or should I provide you a sample?
Posted 7 August 2020, 4:33 am EST
Yes - my issue is fixed I think Thanx for your response!!
