Posted 18 July 2018, 7:23 am EST
Hi. How do I set dataMap for each dynamic row?
Posted by: productinfo on 18 July 2018, 7:23 am EST
Posted 19 July 2018, 2:42 am EST
Since the rows are data-based, the DataMap data for each row is different. How do I create a row-based dataMap for it? I want to solve it with checkbox, but this time the grid (initialized) event did not work when the checkbox changed.
Posted 19 July 2018, 8:21 am EST
The dataMap can only be set for FlexGrid columns and not for rows.
Can you please let us know more about your use case so that we may suggest accordingly?
However, if you mean dynamic dataMap i.e dataMap for a column which changes its value according to the value of some other field in the same row. Please, refer to the following sample:- http://jsfiddle.net/Wijmo5/8brL80r8/
~Manish
Posted 19 July 2018, 9:42 am EST
Example
itemsSource = [
"line_id": 1,
"material_code": "0001",
"material_unit_set": {
"id": 1,
"description": "row_1_unit_1"
"line_id": 2,
"material_code": "0002",
"id": 1,
"description": "row_2_unit_1"
"line_id": 3,
"material_code": "0003",
"id": 3,
"description": "row_3_unit_3"
row1
dataMap = new wjCore.DataMap([
"id": 1,
"id": 1,
"description": "row_1_unit_2"
"id": 3,
"description": "row_1_unit_3"
], 'id', 'description');
row2
"id": 4,
"id": 5,
"description": "row_2_unit_2"
"id": 6,
"description": "row_2_unit_3"
row3
"id": 7,
"description": "row_3_unit_1"
"id": 8,
"description": "row_3_unit_2"
"id": 9,
Grid:
<wj-flex-grid #flexGrid [itemsSource]="itemsSource">
<wj-flex-grid-column [header]="'line_id'" [binding]="'line_id'"></wj-flex-grid-column>
<wj-flex-grid-column [header]="'material_code'" [binding]="'material_code'"></wj-flex-grid-column>
<wj-flex-grid-column [header]="'material_unit_set'" [binding]="'material_unit_set.id'"
[dataMap]="dataMap" [showDropDown]="true"></wj-flex-grid-column>
</wj-flex-grid>
Posted 20 July 2018, 7:11 am EST
Manish ?
Posted 20 July 2018, 8:56 am EST
We are currently working on this case and will update you on Monday.
~Manish
Posted 23 July 2018, 8:06 am EST
DataMap is applied at column level so you cannot have separate dataMap for each row.
However if you want to restrict the values displayed in the dropdown in dataMap then you may do so by overriding the getDisplayValues() method of dataMap.
Please refer to the following sample which implements the same:-
https://stackblitz.com/edit/angular-fhzmga?file=app%2Fapp.component.ts
~Manish
Posted 25 March 2020, 1:04 pm EST
I have a similar problem but I think it’s easier. I have an object that has a series of objects on it.
I would like to display the object’s name on a flexgrid and select an object from the set of objects associated with that object.
It would be two columns Name and Clause, this last one I think would be a dataMap.
This would be the object.
"id": 1,
"name": "RC Explotación",
"abrev": "RX Expl",
"bbr_id": 1,
"active": true,
"syu_cr": 100016,
"syu_mo": 100016,
"clausulas": [
"id": 1,
"bco_id": 1,
"bsc_id": 0,
"name": "Clausula 1",
"text": "",
"active": true
"id": 2,
"bco_id": 1,
"bsc_id": 0,
"name": "Clausula 2",
"text": "",
"active": true
My code is this.
<wj-flex-grid [itemsSource]="formGroup.value.dataCovers" [selectionMode]="'Row'">
<wj-flex-grid-column [binding]="'name'" [header]="'Cobertura'" [width]="'50*'" [isReadOnly]="true"></wj-flex-grid-column>
<wj-flex-grid-column [binding]="'clausulas'" [header]="'Clausula'" [width]="'50*'"></wj-flex-grid-column>
</wj-flex-grid>
Posted 26 March 2020, 5:45 am EST
For your requirements, I would suggest you use ComboBox as a the FlexGrid’s editor instead of using the DataMap. Use the WjFlexGridCellTemplate to bind the ComboBox to the cell and update the values using the Angular’s binding. Also, you will need to store the selected value in another variable so I have added clausulas_id variable which will store the selected id from the clausulas. Please refer to the sample link below:
https://stackblitz.com/edit/angular-wcvtrt
Posted 26 March 2020, 6:27 am EST
Thank you very much, it was just what I needed.
