Wijmo grid Clipboard Support Ctrl+X
Posted by: viju on 19 January 2022, 9:10 am EST
  • Posted 19 January 2022, 9:10 am EST
    Hi we use wijmo grid and want default clipboard support on grid, like copy paste which works, but with cut paste i.e., ctrl+X does not work.
  • Posted 20 January 2022, 7:45 am EST
    We have responded on the support portal. Please refer to the link for the same: https://www.grapecity.com/my-account/my-support/case/CAS-28341-Q4F2L3
    Here is a copy of the response:
    You will need to handle the 'keyup' event of the FlexGrid and then cut the data from the FlexGrid:
    grid.hostElement.addEventListener('keyup', function(e) {
      if(e.ctrlKey && e.key === 'x') {
        const data = grid.getClipString();
        wijmo.Clipboard.copy(data);
        grid.setClipString('');
    }, true)
    You may refer to the sample link below:
    https://stackblitz.com/edit/angular-ca2svn?file=src%2Fapp%2Fapp.component.ts
    Please note that if a column is required (number and date types column are required by default), then the data of that column will not be removed from the FlexGrid.
