Wijmo Grid - Partially Row deletion
Posted by: chhavi.sethi on 8 October 2020, 1:21 pm EST
    Posted 8 October 2020, 1:21 pm EST
    I have been struggling with an issue with deleting a row on the grid.
    When a row is about to be deleted either through delete button or something else, at that point I want to decide with putting a business logic whether that row can be deleted or not which I am doing with the following code.
    this.grid.value.deletedRow.addHandler((flex: WjFlexGrid, event: CellRangeEventArgs) => {
    			event.cancel = true;
    But the only issue happening with this code is, that it does not delete the row(which is fine) but it does delete the data in the cells of that row.
  • Posted 9 October 2020, 1:36 am EST
    Hi Chhavi,
    You will need to use the deletingRow event of FlexGrid instead of the deletedRow.
    https://stackblitz.com/edit/angular-rngpcq
    In this sample, select a row by clicking on its header and press the delete key to delete the row. Rows with even id cannot be deleted in this sample.
  • Posted 9 October 2020, 12:25 pm EST
    Thanks, Aswin,
    It was my bad, I was using the wrong event.
