Wijmo Grid Transponse: convert columns to rows and rows into columns wijmo grid
Posted by: siddushar on 18 December 2018, 7:41 am EST
    Posted 18 December 2018, 7:41 am EST
    Hello all,
    I am using wijmo grid in my angular2 application.
    How can i transpose grid? im facing problem while converting rows into columns and columns into rows.
    i tried following : https://stackblitz.com/edit/angular-fozjd2?file=src%2Fapp%2Fapp.component.html
  • Posted 19 December 2018, 1:43 am EST
    FlexGrid doesn’t support the transposed view so the only option left is to transpose the source data and assign it to the grid just like in the sample you shared.
    However this approach also has its shortcomings such as features like sorting, filtering won’t be supported since they would work on columns and in transposed view that won’t make much sense(since sorting, filtering would be required to work on rows in case of transposed view).
    You may use the approach if it only for viewing purposes and doesn’t require support for advanced grid features.
    We have updated the sample to display row headers as well, you may find the sample here: https://stackblitz.com/edit/angular-fqiphw?file=src%2Fapp%2Fapp.component.ts
    ~Sharad
  • Posted 3 May 2019, 10:57 am EST
    Hi Team,
    Is this answer up to date or there is something new that we can use for the colum-row transpose?
    We are using Angular 7
  • Posted 6 May 2019, 3:05 am EST
    You may use the solution for Angular 7 as well. Let us know if you face any issues.
  • Posted 6 May 2019, 3:37 am EST
    Hello Abhishek,
    Thanks for your reply. Do you mean the above solution or is there any other newer solution available for Angular 7?
  • Posted 8 May 2019, 3:27 am EST
    We have an updated sample to transpose grid. Please refer to the following updated sample and let us know if you face any issues:
    https://jsfiddle.net/Wijmo5/tce6ro57/
  • Posted 9 December 2019, 3:15 pm EST
    Would using a TransposedGrid do the same thing but with a lot less code?
  • Posted 9 December 2019, 11:38 pm EST
    Hi Elyon,
    Yes, you can use the TransposedGrid control to create a transposed grid. Refer to the sample link below:
    https://www.grapecity.com/wijmo/demos/Grid/TransposedGrid/ProductSheet/purejs
