Wijmo License Issue
Posted by: AAl-ismail on 21 July 2020, 7:40 am EST
    Posted 21 July 2020, 7:40 am EST
    Below are few questions-
    1. How do i know the version of Wijmo license i have under my licenses?
    2. What is the stable version of wijmo for 5.20182? I meant the minor version?
    3. Is wijmo 5.20182.* version compatible with Angular 9?
    4. When am using Wijmo 5.20193.646 in my application and use the license key i have it says- “The license in the application is not valid for the versionin use.The license version is 5.20182.* and application version is 5.20193.646”
  • Posted 22 July 2020, 4:22 am EST
    Please go the URL link below:
    https://www.grapecity.com/my-account/my-licenses
    This link will display all of the licenses that you have under your email.
    The stable versions for 5.20182.* are 5.20182.500 and 5.20182.524.
    The 18v2 or 5.20182.* versions are not compatible with Angular 9. The first version that is compatible is 5.20193.637. Also, the unscoped packages are not compatible with angular 9 (referred to as “wijmo” in package.json). So, if you are using version greater than 5.20191.*, I would suggest you upgrade your application to use the scoped packages (referred to as “@grapecity/wijmo.all” in package.json). Please refer to the blog link below that shows how you can easily upgrade to scoped packages:
    https://www.grapecity.com/blogs/wijmo-npm-package-changes
    This error is thrown because your license is not compatible with 19v3. The distribution key that you have added in your application must have been generated by 18v2 license key. The 18v2 key is only compatible upto 19v2. So, in order to use 19v3 version, you will have to renew your license (which it seems that you have already done), create a new distribution key and add it to your application.
    I hope this clears your doubts but let me in case you have any further queries.
  • Posted 23 July 2020, 2:20 am EST
    Hi Ashwin,
    Thanks for prompt response. My issue is resolved now
