Posted 30 August 2019, 5:05 am EST
In refrence to:
https://www.grapecity.com/forums/wijmo/wijmo-multi-select-dropdow
I tried the approach but failed to get result. I am attaching my .less file for reference.
Posted by: reeshabh.choudhary on 30 August 2019, 5:05 am EST
In refrence to:
Posted 30 August 2019, 5:06 am EST
wijmo.less code attached below is my global style for wijmo components.
Posted 30 August 2019, 5:08 am EST
body {
wj-multi-select {
height: 30px;
width: 100%;
border-radius: 2px !important;
.wj-control {
.wj-input-group-btn {
display: none !important;
.wj-dropdown-panel{
z-index: 150000000000 !important;
.wj-content {
border-radius: 0;
border: none;
border: 1px solid rgba(0, 0, 0, .1);
.wj-colheaders {
> div {
background-color: #f6f6f6;
&.wj-flexsheet{
.wj-cell {
text-align: left !important;
padding: 5px 10px !important;
border-color: rgba(0, 0, 0, .1);
color: #444;
font-size: 13px;
font-weight: 400;
.wj-readonly-cell{
background: lightgrey !important;
font-weight: 600;
&.wj-flexgrid:not(.wj-flexsheet){
.wj-cell.wj-alt {
.wj-cell {
padding: 5px 10px 2px !important;
color: #444;
font-size: 13px;
font-weight: 400;
&.wj-frozen-col:not(.wj-header){
background: @white !important;
.form-group,
.form-control {
margin-bottom: 0;
span {
width: 100%;
white-space: nowrap;
text-overflow: ellipsis;
display: inline-block;
overflow: hidden;
.icon {
+ .icon {
margin-left: 10px;
&.wj-glyph-filter {
overflow: visible;
width: auto;
&.wj-glyph-down,
&.wj-glyph-up {
width: auto;
div[wj-part=ch] {
box-shadow: 0 0 10px rgba(0,0,0,.2);
.wj-alt:not(.wj-header):not(.wj-group):not(.wj-state-selected):not(.wj-state-multi-selected) {
background-color: transparent;
.wj-input-group {
border-radius: 0;
border-radius: 0;
>.wj-btn {
border-radius: 0;
&:hover {
border-radius: 0;
.checklist-grid {
.wj-cell {
span {
line-height: 30px;
.wj-multiselect {
margin-top: 0px;
div:empty {
height: 0;
.wj-flexchart {
border: none !important;
padding: 0 !important;
margin-bottom: 0 !important;
.wj-flexchart .wj-gridline{
stroke: #d2d2d2 !important;
My wijmo multi select html code:
<wj-multi-select #multiRef [itemsSource]="items" [dropDownCssClass]="'multi-column'"
(initialized)="initMS(multiRef)"
[displayMemberPath]="'name'" [selectedValuePath]="'value'" [isEditable]="false" [isRequired]="false"
[(checkedItems)]="selectedItemsInput" (checkedItemsChanged)="onCheckedItemsChanged($event)">
</wj-multi-select>
Posted 30 August 2019, 5:09 am EST
Wijmo multi select component.ts code:
import { Component, OnInit, Input, ViewChild, Output, EventEmitter } from '@angular/core';
import * as wjcCore from 'wijmo/wijmo';
import * as wjcInput from 'wijmo/wijmo.input';
@Component({
selector: 'app-wijmo-multi-select',
templateUrl: './wijmo-multi-select.component.html',
styleUrls: ['./wijmo-multi-select.component.css']
export class WijmoMultiSelectComponent implements OnInit {
@Input() items: any;
@Input() selectedItemsInput: any;
@Input() placeholder: any;
@Output() multiSelectChanged = new EventEmitter<any>();
@ViewChild('multiRef') multiRef: any;
selectedItem = [];
constructor() {
ngOnInit() {
console.log('items', this.items);
this.multiRef.placeholder = this.placeholder;
initMS(mls: wjcInput.MultiSelect) {
const dd = mls.dropDown;
dd.style.width = mls.hostElement.offsetWidth + 'px';
onCheckedItemsChanged(e: any) {
this.multiSelectChanged.emit(this.selectedItemsInput);
Posted 2 September 2019, 12:52 am EST
Hi Reeshabh,
From looking at your code, it seems like you have not added the ‘multi-column’ class in you less file. Please make sure that you have added the following code in your main stylesheet:
.multi-column.wj-listbox,
.multi-column .wj-listbox {
display: flex;
flex-wrap: wrap;
.multi-column .wj-listbox-item {
min-width: 200px;
I also added the code provided in my project but the sample was working as expected. Please refer to the sample attached.
Posted 3 September 2019, 5:25 am EST
In the sample code attached, I did npm install and run the code. It is still not showing in drowdown format. Attaching the snapshot as well.
Posted 4 September 2019, 1:32 am EST
From what I understand, it seems that your issue is that the drop-down button is not visible. To show the drop-down button in the MultiSelect, you will need to remove the part shown below from your .less code:
.wj-control {
Let me know if this was your issue or otherwise.
