Wijmo Pivot Panel and Pivot Chart (Pie Chart) not in sync
Posted by: reeshabh.choudhary on 13 March 2019, 1:30 am EST
    Posted 13 March 2019, 1:30 am EST
    Hello Team
    As shown in your demo: https://demos.wijmo.com/5/angular2/OLAPIntro/OLAPIntro/
    , I have implemented a pivot panel and a pivot chart in my project. It works well in all cases except one which came to my notice, and hence mentioning the scenario:
    When we have a combination of pivot panel and pivot chart (PIE CHART) in working, if we try to add fields in rows or values part of pivot panel, value selection and removal does not work in sync for the integrated combo box of pie chart where we can select different fields as per our requirements. This can be referred as the drop down which let us select Sales and Downloads in Pie Chart.
  • Posted 14 March 2019, 3:59 am EST
    I have tried reproducing the issue with mentioned steps but was unable to do so. I have attached the sample that I used to reproduce the issue. Could you please try it out and let me know if you are facing the issue with sample as well.
    Please feel free to modify the sample to reproduce the issue and send it back to us so that we can investigate this in detail.
    https://stackblitz.com/edit/query-pivot-panel-chart
    ~Abhishek
  • Posted 20 March 2019, 1:24 am EST
    As you can see in the image, initially property type and building type were selected, but later on, building type was removed and Data % complete was added, it is still showing building type in list. The list does not get refreshed.
  • Posted 20 March 2019, 1:25 am EST - Updated 3 October 2022, 8:08 pm EST
  • Posted 20 March 2019, 3:04 am EST - Updated 3 October 2022, 8:08 pm EST
    I have attached one more image for reference.
  • Posted 20 March 2019, 3:05 am EST
    How do we manage this drop down since it seems to be specifically part of Pie Chart and I don’t see an option to configure it.
  • Posted 20 March 2019, 4:46 am EST - Updated 3 October 2022, 8:08 pm EST
    Please also find attached the column bindings, which are being updated correctly.
    I am trying to console log ‘this.pivotChartRef._colItms’.
  • Posted 20 March 2019, 4:54 am EST
    Hi Reeshabh,
    It seems like deferUpdate option is checked in your pivot panel. There is a defer update option(at the bottom of the panel UI) in the pivot panel. If it is checked, the chart only updates when you click the “Update” button. Could you please make sure that deferUpdate is not checked.
    If you are still facing issues, could you please share a small sample replicating the issue so that we could further investigate the issue.
    ~Sharad
  • Posted 20 March 2019, 7:41 am EST
    No defer UI update option is not checked in my UI. Let me get back to you with a code sample if possible.
  • Posted 20 March 2019, 8:09 am EST
    Although I can confirm that chart is getting latest values and 1 more bug is found, the dropdown does not take more than 3 parameters
  • Posted 22 March 2019, 2:12 am EST
    We are sorry but we are still unable to reproduce the issue. Could you please have a look at the following sample(used for testing purposes) and let us know if we are missing something to replicate the issue:
    https://stackblitz.com/edit/query-pivot-panel-chart-7ab18x?file=src%2Fapp%2Fapp.component.ts
    In the above sample, 5 fields are pushed as valueFields and DropDown seems to work fine.
    Could you please share a sample replicating the issue that we could investigate?
  • Posted 25 March 2019, 5:01 am EST
    Hi Sharad, I updated my Wijmo version and issue got resolved. Seems like it was an issue in earlier version. Thank you for your efforts and time.
