Posted 29 July 2019, 9:38 pm EST
Hi, is it possible to open the filter for a specific column on keypress like ctrl+f??
I have searched the forum but wasn’t lucky
Helge
Posted by: handerson on 29 July 2019, 9:38 pm EST
Helge
Posted 29 July 2019, 10:28 pm EST
Ok. Found a solution.
window.addEventListener(‘keydown’, e => {
if (e.keyCode === 114 || (e.ctrlKey && e.keyCode === 70)) {
e.preventDefault();
document.getElementsByClassName(‘wj-elem-filter’)[0].click();
document.getElementsByClassName(‘wj-dropdown-panel wj-control wj-content wj-columnfiltereditor wj-state-empty’)[0].classList.add(‘wj-state-focused’);
document.getElementsByClassName(‘wj-dropdown-panel wj-control wj-content wj-columnfiltereditor wj-state-empty wj-state-focused’)[0].classList.remove(‘wj-state-empty’);
But is there a nicer way of getting the job done?
Posted 29 July 2019, 11:46 pm EST
Hi Helge,
You approach regarding handling the keydown event is correct but you may simply call the editColumnFilter method of FlexGridFilter class to open the column filter. Refer to the code snippet and sample below:
document.addEventListener('keydown', e => {
if(e.ctrlKey && (e.key == 'f' || e.key == 'F')) {
e.preventDefault();
gridFilter.editColumnFilter(grid.columns.getColumn('country'));
https://stackblitz.com/edit/js-mcmb7m
