Wijmo Setting the Distribution Key in Angular Application
Posted by: teenu.k on 13 September 2020, 12:15 pm EST
  • Posted 13 September 2020, 12:15 pm EST
    I have UI developed in angular7 and there I used wijmo flexsheet and grid. I also created a distribution key. I have 3 to 4 modules where I used wijmo flexsheet. Is it necessary to set the license key in every module separately or in app.module.ts only? When I set the key separately it worked. iwant to know the best practice we need follow. Any one please respond
  • Posted 14 September 2020, 2:31 am EST
    Hi Teenu,
    You do not need to set the license key in each module file, you can only set it in the main module file or even in the main.ts file. You only have to make sure that no Wijmo controls are initialized before setting the license key.
