Wijmo sub-menu
Posted by: gkukko on 25 February 2019, 8:27 am EST
  • Posted 25 February 2019, 8:27 am EST - Updated 3 October 2022, 7:40 pm EST
    I am facing issue while using sub-menus in Angular 2. If we set property openOnHover to true, then it works as expected but when the focus/cursor is moved out of the menu controls then entire menus got disappear. I think it should not be standard behavior as cursor might get move by mistake.
    Also not sure if the behavior is intentional or not, but what I observe is, if user moves the cursor over the sub-menu and if there is no space available on right side for menus to render then menus are getting overlapped with parent menus, even there is space available on the left side.
    Please find the attachment.
    Please let me know if you need more information.
  • Posted 26 February 2019, 4:26 am EST
    This behaviour is by design. Also, an enhancement request already exists for this requirement(to not close the menu on mouseleave), we have added you as correspondence for the case and will let you know regarding any updates on this. Internal tracking Id fro the issue is: 362723
    This is also a design behaviour. Submenus are displayed on the right of the menu to keep the natural reading flow(left to right) and if enough space is not available then they are shifted to the left only enough that the submenu could fit the screen.
    ~Sharad
  • Posted 13 May 2019, 9:45 am EST
    We just added a property to solve this issue in build 605.
    It is called Menu.closeOnLeave https://www.grapecity.com/wijmo/api/classes/wijmo_input.menu.html#closeonleave
    Here is a demo that sets closeOnLeave to false when openOnHover is set to true (since they work in unison). https://jsfiddle.net/Wijmo5/kpa6g4n2/
  • Posted 18 June 2019, 7:07 am EST - Updated 3 October 2022, 7:40 pm EST
    Thank you Chris.
    With this, I saw a new issue. If openOnHover = true, and user clicks on multiple menus containing sub-menus, then sub-menus never get hidden.
    To replicate this please follow below steps
    Please refer attached screenshot.
  • Posted 19 June 2019, 6:16 am EST
    We were able to replicate the issue at our end so we forwarded the issue to the dev team as a bug report with internal tracking id 385244. We will give you an update as soon as the issue is resolved.
  • Posted 19 August 2019, 10:16 am EST
    This was fixed and confirmed in our latest release (build 5.20192.624)
    Thanks so much for the request and taking the time to report the issue.
