Wijmo treeview image size
Posted by: mark.nebrat on 31 May 2019, 9:50 am EST
    Posted 31 May 2019, 9:50 am EST
    Hello
    With imageMemberPath property i can specify some image.
    How can i format it - set width,height and other img properties
  • Posted 3 June 2019, 4:27 am EST
    If you need to only style the img, then you could use CSS to style the image. Please refer to the following code snippet:
    .wj-treeview .wj-node img{
    	width: 25px;
    	height: 25px;
    However, if you need to perform some advanced operation such as adding event listeners on the image then you could use the formatItem event to get the instance of the rendered image element and perform the required operations. In the formatItem event, the node element is passed as event data which contains the image element from imageMemberPath. Please refer to the sample below which demonstrates the use of formatItem:
    https://stackblitz.com/edit/js-ce8j6l
    API Reference:
    • formatItem: https://www.grapecity.com/wijmo/api/classes/wijmo_nav.treeview.html#formatitem
    • FormatNodeEventArgs: https://www.grapecity.com/wijmo/api/classes/wijmo_nav.formatnodeeventargs.html
  • Posted 3 June 2019, 4:00 pm EST
    Thank you very much
