Wijmo5 Flexgrid column sorting for alphanumeric value
Posted by: rambabu on 14 September 2017, 11:44 am EST
    Posted 14 September 2017, 11:44 am EST
    I have an issue with sorting in wijmo Flexgrid.
    I have aplhanumeric values in a column and when i click on its header for sorting, the values which are aplhanumeric are not sorting properly.
    For example,
    consider this list : A1203,1110,A100,230
    If i click on header to sort it should sort like A100,A1203,230,1110, instead it sorting is like A1203,A100,230,1110.
    Could you please provide a solution for sorting for alphanumeric numbers.The fiddle link for it is http://fiddle.jshell.net/Teja_Gudivada/mjdxkztf/.
    Thanks & Regards
  • Posted 14 September 2017, 11:44 am EST
    Hello Rambabu,
    You can sort alphanumeric values using sort comparer method of collection view with Dave Koele’s Alphanum algorithm. This will sort all the values alphanumerically.
    For reference, kindly see the updated fiddle http://fiddle.jshell.net/mkgupta911/mjdxkztf/1/, which implements the same.
    Hope this will help you.
    Manish Kumar Gupta
    Thanks Manish Kumar Gupta for you response,it is really helpful.
    Thanks & Regards
  • Posted 9 March 2022, 1:53 pm EST
    Hello Manish. Can u please share the fiddler again? I also need similar behavior. thanks.
  • Posted 10 March 2022, 5:40 am EST
    You may refer to the sample link below demonstrating the same:
    https://stackblitz.com/edit/angular-efmzbr?file=src%2Fapp%2Fapp.component.ts
    You can update the custom function(compareFn) used to compare values as per your requirement.
