Wj-combo default value selection
Posted by: kun.leeing on 10 June 2020, 11:59 pm EST
    Posted 10 June 2020, 11:59 pm EST
    Hi Team,
    Just met an issue with wj-combobox
    <wj-combo-box
                      [itemsSource]="Values"
                      [displayMemberPath]="'name'"
                      [selectedValuePath]="'value'"
                      [(ngModel)]="input.value"
        </wj-combo-box>
    The effect was that after loaded, the default item got selected, but the value did not put into the input.value. You have to manually select from dropdown and select, then the input.value get assigned.
    Does anyone know the reason about this?
  • Posted 11 June 2020, 12:33 am EST
    Hi Kun,
    The ComboBox binding does not work properly with ngModel. You may use the selectedValue property to bind the value:
    <wj-combo-box
                      [(selectedValue)]="input.value"
    </wj-combo-box>
  • Posted 11 June 2020, 12:49 am EST
    That works perfect. Thanks, mate.
