Wj-flex-grid does not show data correctly on my browser
Posted by: thuanpv on 30 April 2019, 5:23 am EST
    Posted 30 April 2019, 5:23 am EST - Updated 3 October 2022, 8:04 pm EST
    Hi supporters,
    I got a weir problem need your support. Here is the detail.
    1. I try setup my angular project to make it similar to the one in here: https://stackblitz.com/edit/angular-bsgbzr?file=app%2Fapp.component.ts
    There is no error displayed in the console of my browser (chrome), but the data was display incorrectly , please see the picture
  • Posted 30 April 2019, 5:26 am EST - Updated 3 October 2022, 8:04 pm EST
    Here is the console log, please help me to figure it out
  • Posted 30 April 2019, 7:12 am EST
    This is happening because Wijmo’s CSS file is not loaded. In an angular application, you need to add a reference to wijmo’s CSS file which is located in the directory:
    ‘node_modules/wijmo/styles/wijmo.css’
    In your angular-cli.json, you need to add this file:
    "apps": [{
        "styles": [
              "../node_modules/wijmo/styles/wijmo.css",
               "styles.css"
    In the sample you provided, this file has already been added.
  • Posted 1 May 2019, 1:19 pm EST
    Hi abhishek,
    Thank you very much for your support,
    I am using the version Wijmo-Enterprise.20173.409, in the package.json, to install wijmo I add the following code:
    “wijmo”: “file:///D:/iGreenSoftware/WijmoEnterprise/Wijmo-Enterprise.20173.409/NpmImages/wijmo-commonjs-min”. however, in this folder “wijmo-commonjs-min” there is no css file found. I only found the .css in the samples that were included in the package Wijmo-Enterprise.20173.409, named wijmo.min.css. So i used this css file in my app and it worked perfectly.
    So, yes, the problem is about .css and your suggestion is the key to unlock it.
    I just have a confusion that I feel like there is no official .css file included in the enterprise version. (therefore i have to look into the samples included). What is your comment about this ?
    Thuan.
  • Posted 2 May 2019, 6:10 am EST
    Hi Thuan,
    In previous builds, CSS files were not include separately in the NpmImages folder. You need to copy the styles files from Wijmo-Enterprise.20173.409/Dist/styles folder into your application.
