Wj-flex-grid rendering issue
Posted by: kun.leeing on 24 June 2019, 9:55 pm EST
    Posted 24 June 2019, 9:55 pm EST
    Hi there,
    We are putting several wj-flex-grid with a dynamic columns to the separate pages in a ngtabs . For the first time of loading and rendering, it sometimes shows a rendering issue as it is not showing everything correctly, just a few cells which is part of the records. Then I put a refresh button onto the page for testing reload the data and refresh the grid. Then almost every time it could not be rendered correctly. Sometimes, one got the issue , sometimes both.
    Then I checked html generated, I found an inconsistent in wj-flex-grid-column and the <div wj-part above it. For example,
    It has the dom
    <wj-flex-grid-column _ngcontent-c25="" wj-directive-id="4" ng-reflect-binding="TestName" ng-reflect-header="Test Name" ng-reflect-width="200" ng-reflect-allow-resizing="false" ng-reflect-visible="true" style="display: none;"><div></div></wj-flex-grid-column>
    But there is no
    <div class="wj-row"><div tabindex="-1" class="wj-cell wj-header d-flex align-items-end" style="left: 0px; top: 0px; width: 220px; height: 130px; z-index: 1;"><span _ngcontent-c25="">Test Data</span></div>
    corresponding to it.
    Could someone let me know the reason of this effect?
    Thanks in advance.
  • Posted 24 June 2019, 10:01 pm EST
    Sorry, forgot one thing. on the ngb-tabset, I put [destroyOnHide]=“false” for performance consideration. If turn it to true, there is no this issue.
  • Posted 25 June 2019, 6:59 am EST
    We are sorry but we were not able to replicate the issue at our end. Please refer to the sample below which we used to replicate the issue:
    https://stackblitz.com/edit/angular-bjpjgx
    Could you please tell whether we are missing something? You may also update the provided sample or provide with your own sample that replicates the issue.
  • Posted 26 June 2019, 4:25 am EST
    Hi abhishek,
    Thanks for replying and your sample project. Because of that, it is fixed after upgrading wijmo from 5.20183.568 to 5.20191.615.
    Cheers
