Wj flexsheet: Column Header displaying binding value from ColumnLayout
Posted by: reeshabh.choudhary on 5 April 2019, 4:44 am EST
  • Posted 5 April 2019, 4:44 am EST
    After upgrading wijmo version from 5.20182.500 to 5.20183.568, wj-flex-sheet is displaying binding value from custom column layout as header instead of showing header value as header.
    our custom column layout has object in folloing structure:
    binding : “binding value”,
    header : “Header1”,
    isReadOnly : false,
    dataType : 1
    while debugging, I can see that flexsheet columns has header value assigned correctly, but while displaying, they are displaying the binding value in new version. Working perfectly fine in older version.
  • Posted 5 April 2019, 7:35 am EST
    We are sorry but we were not able to replicate the issue at our end. Please refer to the sample that we used to replicate the issue.
    https://stackblitz.com/edit/angular-5zpjfs
    Feel free to modify the sample so that it replicates the issue.
  • Posted 9 April 2019, 1:03 am EST - Updated 3 October 2022, 8:07 pm EST
    HI,
    I tried the code sample, now I am facing a few issues, such as, the index on left side is limited to 9. Please refer photo attached.
  • Posted 9 April 2019, 2:21 am EST
    Also please explain how do you use wijmo flexsheet columnLayout?
  • Posted 10 April 2019, 3:29 am EST
    Please check this :
     initFlexSheet(flex: wjcGridSheet.FlexSheet) {
        if(flex) {
          console.log(flex.itemsSource)
          flex.sheets.selectedIndex = 0;
          flex.columns.push(new wjcGrid.Column({
            header: 'Country',
            binding: 'country',
            isReadOnly: true
            binding: 'amount',
            header: 'Total',
            isReadOnly: true
          this.source.items.forEach((item, index) => {
            flex.setCellData(index, 0, item.country);
            flex.setCellData(index, 1, item.amount);
          flex.selectedSheet.columnCount = 10;
    itemsSource comes null. Even if you add click event to wijmo flexsheet after data is loaded and check, itemsSource will come as null for it.
  • Posted 10 April 2019, 6:15 am EST
    Index visible only up to 9
    The width of the row header is small, therefore indexes greater than 9 are truncated and shown as an ellipsis(…). You can use the autoSizeColumn method to resize the headers:
    flexSheet.autoSizeColumn(0, true);
    API Reference:
    https://demos.wijmo.com/5/Angular/WijmoHelp/WijmoHelp/topic/wijmo.grid.sheet.FlexSheet.Class.html#autoSizeColumn
    How to use columnLayout
    The columnLayout property is used to save the layout of the columns of flex sheet in JSON format.
    API Reference:
    https://demos.wijmo.com/5/Angular/WijmoHelp/WijmoHelp/topic/wijmo.grid.sheet.FlexSheet.Class.html#columnLayout
    Please refer to the demo below that shows how to columnLayout property:
    https://demos.wijmo.com/5/PureJS/LearnWijmo/LearnWijmo/#daxp8gm6
    Note: This demo is using wijmo FlexGrid but it is the same for FlexSheet
